Re: E-Hybrid Setup Ideas
Born to be WillD /
> 🇮🇹💦 Of the Loin wrote:
> Make sure you have a plan in place to deal with excess current generated
> by your motor when it's driven by the gas engine.
> Every motor is also a generator
> You could damage your battery severely if you don't account for this
I'm pretty sure that was what happened to team T3's e-FWD hybrid
I made a 2wd hybrid & used a bicycle hub motor on front that had internal freewheel so it could coast, as opposed to the higher power direct drive motorcycle hubs which I think run into the above problem. It worked very much like pedaling from a stop, so i could gear higher. also made it easy to start haha. push the e to go, tug the starter to start the ICE, they compliment each other til gas takes over and everyone's happy. I'm not sure it was worth it, but i liked it a lot.
you dont lose pedals or anything tho, why would you, if the electric drives the front, depending on bike the pedals drive the drivechain or a freewheel on back, that doesnt change if you put a motor up front.
If you did it with a puch or whatever that's got a separate pedal crank and ran a chain drive motor on the pedal side, you'd have a freewheel, so you also avoid the battery backcharge. but now you dont have pedals
