So Im playing with LEDs toward an eventual turn signal install and im trying to puzzle out the basic function of the electrical system.
I get the idea that the generator produces X watts and you try to load up all your bulbs to match that output. But my KTM Foxi has a headlight on-off switch as well as hi-low beam. If you plan the load of the headlight bulb in your overall wattage, what happens when you turn it off? Those 10-20 watts need to go somewhere, even when the thing was new. So what kept it from blowing bulbs ahen the headlight was off?
I have an H3 LED headlight bulb that lights, but I've burned a few various bulbs in testing. I've left the halogen bulb as a wattage sink to save ths rest until I figure out a solution. I'm using several LED bulbs, 6-12v capable by design and they seem to hold up as long as the headlight is on.
Can I add a resistor somewhere to act as a power sink to use the H3 LED? My eventual issue is the digital LED blinker unit ive got seems to be rather power hungry, so I want to be able to give it as much power as it wants, but that would only be intermittent, so that can't really factor into the power load very well. Having a dump resistor would also steal power from the blinker, but maybe i could have the power to the resistor disconnect when the blinkers are switched on?
I think the easy answer is put on a 4 terminal regulator/rectifier but the LEDs I have seem to work fine without a rectifier and it's saving me the wiring hassle. I could go a regulator and skip the rectifier, but that's a maybe.
