Piaggio Bravo Performance Variator
Hello people,
So I got parts needed to convert my bravo from single speed to variomatic.
And I have to decide what front variator I am going to buy.
So I found 3 variators: Malossi, Polini and Pinasco which one is the best?
For me Malossi and Polini looks better than Pinasco. But I don't know anything about them.
Price is not a problem.
Also shortly is it worth to upgrade from Olympia 65 kit to DR 65?
Thanks.
Moped specs:
Giannelli fire Pipe, Olympia 43mm kit ported+ higher timing and almost 30mm wide exhaust port, intake (carter) timing 175 degrees.
With single speed tr. goes 72km/h GPS
Re: Piaggio Bravo Performance Variator
Thomas 556 /
So I am going with polini variator, malossi belt, and polini blue spring for rear variator. Choosed polini because it has highest quality.
Thomas 556 /
And malossi clutch bell as I don’t want to stock one to explode.
🦺🥇b to the MOPO 🚨🚨🚨 eff /
I'm no expert on this, but from what I've read here the stock rear contra spring is fine.
Dirty30 Dillon /
I have found the stock euro contras to be great for mild setups like this. Polini variator is the best standalone unit.
Given your build, I would only really worry about exploding a bell if your plans are to rev on the stand.
Thomas 556 /
Thanks
Always gotta rev your vespa on the stand so you know it's good.
Just kidding for the love of God don't do that
Wait... What? You don't rev Vespas on the stand? That's the best part of mopeds
