Re: strange drive problem
Totally normal JBOT /
I’ve told you your issues.
Get a stronger spring (1500-2000 spring) and a launch lever, then retune. You could try to add an extra spring but you don’t have the room so GET A STRONGER SPRING LOL. I’m using a stronger spring than you are with my 50cc moby.
The belt’s side angles not fitting well is because er3 has steeper cheeks than most standard V belts to allow more variation at fully closed. They tend to eat belts, especially when you don’t have enough tension on the belt due to a weak spring.
French style bikes want to get as much variation as possible, and often cheek angles vs belt angles don’t match to achieve that end goal. With a baby weak spring those few mm of belt will slip like crazy. With a stronger spring it will grab. Slip creates heat. With a launch lever you can manually add more tension without a stronger spring.
Got it?
  strange drive problemTopic by: Alan Jackson Alan Jackson 10/16/21 11:16AM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 10/16/21 11:36AM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 10/16/21 03:22PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 10/16/21 11:40PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 10/16/21 11:42PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 10/17/21 02:02AM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 10/18/21 04:08PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 10/18/21 08:28PM
  Re: strange drive problemRe: Graham Motzing Graham Motzing 10/18/21 09:39PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 10/19/21 12:05AM
  Re: strange drive problemRe: Dirty30 Dillon Dirty30 Dillon 10/19/21 09:54AM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 10/19/21 11:12AM
  Re: strange drive problemRe: Graham Motzing Graham Motzing 10/19/21 12:57PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 10/19/21 01:26PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 10/21/21 04:46PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 10/21/21 06:23PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 10/22/21 12:31PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 10/22/21 01:57PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 10/23/21 12:46AM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 10/23/21 01:49AM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 10/20/21 11:42AM
  Re: strange drive problemRe: Graham Motzing Graham Motzing 10/20/21 02:40PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 10/20/21 06:33PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 07/10/22 08:49AM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 07/10/22 11:40AM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 07/10/22 11:47AM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 07/10/22 12:29PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 07/10/22 01:16PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 10/16/21 12:56PM
  Re: strange drive problemRe: Graham Motzing Graham Motzing 10/16/21 01:18PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 07/10/22 01:18PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 07/10/22 01:33PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 07/10/22 01:35PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 07/10/22 01:39PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 07/11/22 05:04AM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 07/11/22 12:24PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 07/11/22 01:10PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 07/11/22 02:03PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 07/12/22 03:55AM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 07/12/22 02:00PM
  Re: strange drive problemRe: Alan Jackson Alan Jackson 07/13/22 03:46PM
  Re: strange drive problemRe: Totally normal JBOT Totally normal JBOT 07/13/22 04:27PM
