Re: Pug clutch vario vs clutch pulley
Graham Motzing /
There are some good posts on radiator options, Andy scouten has posted some you tube vids as well that walk through a H2O setup. Just make sure you get all the air out of the system before you start giving it the beans.
If you keep the timing low and run heavy weights to start with, it will give you a lot more margin for error as you tune. Worst thing you can do is high timing, air leak (or rings not seated) and high rpm with no load. Running heavy weights will keep the engine from wanging up to a million rpm while you're still trying to figure everything out.
  Pug clutch vario vs clutch pulleyTopic by: Scottee doesn't know. Scottee doesn't know. 10/11/21 12:58PM
  Re: Pug clutch vario vs clutch pulleyRe: 666 420 666 420 10/11/21 02:58PM
  Re: Pug clutch vario vs clutch pulleyRe: Graham Motzing Graham Motzing 10/11/21 03:28PM
  Re: Pug clutch vario vs clutch pulleyRe: Scottee doesn't know. Scottee doesn't know. 10/11/21 09:22PM
  Re: Pug clutch vario vs clutch pulleyRe: Toledo Riot Toledo Riot 10/25/21 10:25AM
  Re: Pug clutch vario vs clutch pulleyRe: Scottee doesn't know. Scottee doesn't know. 10/25/21 01:56PM
  Re: Pug clutch vario vs clutch pulleyRe: Toledo Riot Toledo Riot 10/28/21 11:56AM
  Re: Pug clutch vario vs clutch pulleyRe: Graham Motzing Graham Motzing 10/28/21 07:27PM
  Re: Pug clutch vario vs clutch pulleyRe: cheetahchrome . cheetahchrome . 11/06/21 09:45AM
  Re: Pug clutch vario vs clutch pulleyRe: cheetahchrome . cheetahchrome . 11/06/21 09:51AM
  Re: Pug clutch vario vs clutch pulleyRe: Graham Motzing Graham Motzing 11/06/21 02:39PM
  Re: Pug clutch vario vs clutch pulleyRe: Scottee doesn't know. Scottee doesn't know. 11/06/21 10:02AM
  Re: Pug clutch vario vs clutch pulleyRe: cheetahchrome . cheetahchrome . 11/06/21 10:09AM
  Re: Pug clutch vario vs clutch pulleyRe: cheetahchrome . cheetahchrome . 11/06/21 10:11AM
  Re: Pug clutch vario vs clutch pulleyRe: cheetahchrome . cheetahchrome . 11/06/21 10:13AM
  Re: Pug clutch vario vs clutch pulleyRe: Scottee doesn't know. Scottee doesn't know. 11/06/21 10:19AM
  Re: Pug clutch vario vs clutch pulleyRe: Scottee doesn't know. Scottee doesn't know. 11/06/21 10:16AM
