Re: Pug clutch vario vs clutch pulley
Graham Motzing /
In my experience walking that line means airsal 46 smallport kit detuned with lower compression and backed off timing. Still plenty of power but it won't over heat and you can use a stock vario and clutch no probs with good accel. I think the malossi iron is also well liked, people even say polini w is good but maybe more overheating risk? I don't know I haven't run the latter two. The small port airsal matches to euro stock cases, pretty much anything else is higher rpm and needs a lot of porting with new cases.
You can run the simonini for a nice midrange blaster, or there might be other pipes I'm not familiar with, but even a stock pipe will do pretty solid mid 40, albeit not a rocket ship getting there.
  Pug clutch vario vs clutch pulleyTopic by: Scottee doesn't know. Scottee doesn't know. 10/11/21 12:58PM
  Re: Pug clutch vario vs clutch pulleyRe: 666 420 666 420 10/11/21 02:58PM
  Re: Pug clutch vario vs clutch pulleyRe: Graham Motzing Graham Motzing 10/11/21 03:28PM
  Re: Pug clutch vario vs clutch pulleyRe: Scottee doesn't know. Scottee doesn't know. 10/11/21 09:22PM
  Re: Pug clutch vario vs clutch pulleyRe: Toledo Riot Toledo Riot 10/25/21 10:25AM
  Re: Pug clutch vario vs clutch pulleyRe: Scottee doesn't know. Scottee doesn't know. 10/25/21 01:56PM
  Re: Pug clutch vario vs clutch pulleyRe: Toledo Riot Toledo Riot 10/28/21 11:56AM
  Re: Pug clutch vario vs clutch pulleyRe: Graham Motzing Graham Motzing 10/28/21 07:27PM
  Re: Pug clutch vario vs clutch pulleyRe: cheetahchrome . cheetahchrome . 11/06/21 09:45AM
  Re: Pug clutch vario vs clutch pulleyRe: cheetahchrome . cheetahchrome . 11/06/21 09:51AM
  Re: Pug clutch vario vs clutch pulleyRe: Graham Motzing Graham Motzing 11/06/21 02:39PM
  Re: Pug clutch vario vs clutch pulleyRe: Scottee doesn't know. Scottee doesn't know. 11/06/21 10:02AM
  Re: Pug clutch vario vs clutch pulleyRe: cheetahchrome . cheetahchrome . 11/06/21 10:09AM
  Re: Pug clutch vario vs clutch pulleyRe: cheetahchrome . cheetahchrome . 11/06/21 10:11AM
  Re: Pug clutch vario vs clutch pulleyRe: cheetahchrome . cheetahchrome . 11/06/21 10:13AM
  Re: Pug clutch vario vs clutch pulleyRe: Scottee doesn't know. Scottee doesn't know. 11/06/21 10:19AM
  Re: Pug clutch vario vs clutch pulleyRe: Scottee doesn't know. Scottee doesn't know. 11/06/21 10:16AM
