Pug clutch vario vs clutch pulley
Scottee doesn't know. /
got myself a frenchy boi.
preferences of a clutched variator vs clutched pulley?
Re: Pug clutch vario vs clutch pulley
Tweaker trash /
Clutch pully is 10x better
The pug vario clutch is actually pretty good, it can be tuned and has a nice engagement. It's great for stock and even your middle of the road kitted builds.
The clutch pulley is much more aggressive, it takes a lot of work to make it really work well but once it's dialed in it will let you rip on screamer high rpm ripper setups.
Usually if you have to ask, you will want to run the stock setup. There is plenty of info on stock vario tuning including a really good thread that just got bumped. If you really build to the next level you will know when it's time.
Was kind leaning toward a H20 build.
Just figured if there was a bike to do it on this is it.
French problems and all.
I'll find the thread and check it out.
