Re: No chain tensioner, small sprocket, it's actually a pedal bike!
Probably Fred /
Peddling itself is not a good idea because you’re spinning the bell and and gear inside the engine which wears the clutch bell bushing and makes you do more a lot more work peddling.
not recently but I pop the chain off if I break down making it way easier to pedal and push the bike,
How about you make a way you can disengage the engine or make a free wheeling countershaft drive sprocket for the engine and then let us know what you did.
