Motobecane/jog hybrid “dirtped” 2.0 (more serious this time)
First attempt wasn’t a fail but not a success ether.
Exhaust suck
Motor mount sucked
It’s was horrible
Fix motor mount first to prevent double swinging action.
Welding a bracket up to lock the motor at one position
Re: Motobecane/jog hybrid “dirtped” 2.0 (more serious this time)
Totally normal JBOT /
Your builds look like you make them high on ether
10x better
Gotta order some bushings from McMaster
Definitely high on something but it ant like we have the same genes
That setup would benefit from having the bolt and mount on the outside of the frame mounts.
It’s going to put a lot of torque on the inner. Probably not enough to twist it off but enough to twist for sure.
Yea I know I thought about that all last night
Exhaust relocated so it doesn’t melt my shoe and I can also use a full peg instead of half of one (edited)
Decided to quite
Need a ball joint or something to flex because the exhaust goes into a crazy angle all fully variated. trying to using a hinge mount is impossible without ball joint
Also need a pully clutch
Another $300
So saying that I could just build a solid av10
Motor will sit until I get enough parts
(Edit: absolutely a night mare in the dirt, motor shakes like crazy and gets beat around
You can get a mid pipe ball joint.
Look up snowmobile ball joint. They are like $15 or less
Smallest one I found was 1 7/8”
I need about an 1” (28mm = 1.1 inch )
I could make on with my press but dam dude. maybe I will but I’m worried it won’t seal
Put it in the body of the pipe duh
I use a 1 3/4 I think
I’m going to need a bigger pipe
This is probably true!
“Don’t be a hypocrite like my sister”
