Re: Moped data acq attack
Graham Motzing /
Yeah getting the table isn't hard I can get one online or if I buy good name brand thermistors I can get it from the mfg, I just don't want to figure out how to program it to use the table.
I'm using an NTC thermistor instead of an RTD because they are cheaper and the resistance changes more significantly so you don't need a separate amplifier chip. Ultimately you only get 1023 bits from the analog input and they are spaced evenly from 0-3.3v so the challenge is getting your dv/dtemp as large as possible in the effective range you want to measure. If you want to push the range all the way out to the max of 300c that means you will have fairly poor resolution at room temp, which is fne just kinda annoying when it's jumping 20 degrees just sitting there. There are a couple tricks I can use to smooth the data, and I've also heard to use a filter cap on the circuit although that's more components I would like to avoid.
  Moped data acq attackTopic by: Graham Motzing Graham Motzing 10/01/21 03:31PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/01/21 03:57PM
  Re: Moped data acq attackRe: * wormdirt * * wormdirt * 10/01/21 05:59PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/01/21 06:54PM
  Re: Moped data acq attackRe: daan SJAARLOOS daan SJAARLOOS 10/01/21 06:34PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/01/21 09:05PM
  Re: Moped data acq attackRe: Poop Wizard Poop Wizard 10/01/21 08:29PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/01/21 09:00PM
  Re: Moped data acq attackRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/01/21 09:13PM
  Re: Moped data acq attackRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/01/21 08:53PM
  Re: Moped data acq attackRe: Full Tuck Full Tuck 10/02/21 12:15AM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/02/21 10:34AM
  Re: Moped data acq attackRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/02/21 01:20PM
  Re: Moped data acq attackRe: Jesse Stephenson Jesse Stephenson 10/02/21 01:00PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/02/21 03:02PM
  Re: Moped data acq attackRe: Jesse Stephenson Jesse Stephenson 10/02/21 04:28PM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/02/21 03:04PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/02/21 07:40PM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/02/21 09:31PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/03/21 10:56AM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/03/21 03:53PM
  Re: Moped data acq attackRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/04/21 10:36AM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/02/21 03:21PM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/02/21 05:39PM
  Re: Moped data acq attackRe: Jesse Stephenson Jesse Stephenson 10/02/21 07:16PM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/03/21 11:06AM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/04/21 12:22AM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/04/21 09:49AM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/04/21 03:01PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/04/21 03:19PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/04/21 03:25PM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/04/21 04:21PM
