Re: Moped data acq attack
Graham Motzing /
Resolution is whatever I want within reason, I've got a pretty long delay in there right now because if you don't, the numbers can't draw fast enough and they get all blurry, but I'm going to add a Max temp function (real simple, just if new temp is greater, save new temp to Max temp each loop) and the write to the SD card will take a couple clicks, so practically speaking probably about 20 times a second without getting into fancy timers and stuff.
When I'm on the computer one of these nights, I'll put up all the links to the parts and a wiring diagram. I was just doing a little toilet-based research and found that you need to use a resistor similar to the resistance of the thermistor at the temp you want to read for the voltage divider, to keep it in the effective range of the response curve. I don't totally understand all the mumbojumbo but I saw 4.7k instead of 100k so I'll try that and see what happens.
  Moped data acq attackTopic by: Graham Motzing Graham Motzing 10/01/21 03:31PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/01/21 03:57PM
  Re: Moped data acq attackRe: * wormdirt * * wormdirt * 10/01/21 05:59PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/01/21 06:54PM
  Re: Moped data acq attackRe: daan SJAARLOOS daan SJAARLOOS 10/01/21 06:34PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/01/21 09:05PM
  Re: Moped data acq attackRe: Poop Wizard Poop Wizard 10/01/21 08:29PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/01/21 09:00PM
  Re: Moped data acq attackRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/01/21 09:13PM
  Re: Moped data acq attackRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/01/21 08:53PM
  Re: Moped data acq attackRe: Full Tuck Full Tuck 10/02/21 12:15AM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/02/21 10:34AM
  Re: Moped data acq attackRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/02/21 01:20PM
  Re: Moped data acq attackRe: Jesse Stephenson Jesse Stephenson 10/02/21 01:00PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/02/21 03:02PM
  Re: Moped data acq attackRe: Jesse Stephenson Jesse Stephenson 10/02/21 04:28PM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/02/21 03:04PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/02/21 07:40PM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/02/21 09:31PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/03/21 10:56AM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/03/21 03:53PM
  Re: Moped data acq attackRe: 🇮🇹💦 Of the Loin 🇮🇹💦 Of the Loin 10/04/21 10:36AM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/02/21 03:21PM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/02/21 05:39PM
  Re: Moped data acq attackRe: Jesse Stephenson Jesse Stephenson 10/02/21 07:16PM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/03/21 11:06AM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/04/21 12:22AM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/04/21 09:49AM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/04/21 03:01PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/04/21 03:19PM
  Re: Moped data acq attackRe: Graham Motzing Graham Motzing 10/04/21 03:25PM
  Re: Moped data acq attackRe: b to the eff b to the eff 10/04/21 04:21PM
