Re: av10 Variotop shimming? reverse model?
Scottee doesn't know. /
polini head + kit
its a doppler pulley ( clutch version) up against the bushing for the pedal shaft.
the pivot spacers in the head are stock. with a spacer on the stator side to push the engine to the variator side as far as possible.
im reading they can be ground down or replaced with thinner ones.
> Graham Motzing wrote:
> Is your driven pulley spaced wrong? Do you have the right engine mount
> spacers, head?
