av10 Variotop shimming? reverse model?
Scottee doesn't know. /
adding this variator to an AV10 build. mobylette 50v
the variator doesnt line up with the pulley with out some spacing. ( alot of spacing)
a stack of washers led to only a scary few threads for the nut to tighten.
we used less washers for a slightly misaligned pulley but as the nut tightened the variator on the crank it was sandwiched into the case and wouldnt turn.
solutions=
*** theres a correct low profile shim to use?
*** the reverse variator would have closer pulley alignment.
