Re: Widen swingarm without welding
Born to be WillD /
> baird co wrote:
> Get a piece of allthread, or a long axle, put two nuts on it and some
> big washers, and stick it in the drop outs with the nuts and washers on
> the inside.
> Then turn the nuts out so it spreads the swingarm.
> Try to make sure it spreads evenly, or keeps your chain line where you
> want it , etc.
> And make sure the bolt doesn't squirt out and hit you in the face under
> tension.
> You'll have to go wider than you need because it'll try to squeeze back
> to it's original shape.
> Make sure the tubes don't kink,crack, etc.
I had to widen my garelli swingarm for the electric hub motor setup i built a few years ago, I did basically this, drift it apart with allthread. it worked but it wasnt a big stretch
