Re: Widen swingarm without welding
Aaron Goldman /
> Dickie Thompson wrote:
> > > Are you only widening the drop outs to account for the wider hub, or
> > are
> > > you trying to fit a wider hub + wider tire?
> > It has been a while since I last tinkered with this project but I'm
> 85%
> > sure it's just the hub. I believe the tire has no issue fitting.
> Did you already confirm that the chain alignment will work?
Don't think so, good idea. I'll give that a whirl first and see if it can still be centered. Would be a bummer for sure, I wanted the bigger drum brakes.
