Re: Puch Maxi intake airleak - having trouble finding solution
andy eddy /
"If the end of the intake that goes into the carb has a rounded edge where it should meet the o ring , it's likely your problem .
Best to flatten that end for a better seal against the o ring"
Here's what it looks like:
it is slightly rounded. this might be it. if this is indeed the problem how would you recommend flattening it.. grinding it? sanding it? replacing it?
"Did you change the intake to a aftermarket 15mm intake?"
It is the correct intake. 15mm. worked with other bings of the same size.
"Anyhow I ended up using the yellow Teflon tape"
I've heard teflon tape and I've heard furnace tape. Can anyone speak to which is better? or maybe a better question is how permanent and reliable of a fix is this? I want to leave the days of air leaks behind me with this ped. (edited)
  Puch Maxi intake airleak - having trouble finding solutionTopic by: andy eddy andy eddy 09/28/21 06:49PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: pat splat pat splat 09/28/21 08:35PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: P D P D 09/28/21 09:01PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: Graham Motzing Graham Motzing 09/29/21 12:57PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: Probably Fred Probably Fred 09/28/21 10:33PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: Kevin Bishop Kevin Bishop 09/29/21 09:35AM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: Mike Boyd Mike Boyd 09/29/21 12:05PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: andy eddy andy eddy 09/29/21 11:45AM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: Aaron Blair Aaron Blair 09/29/21 12:21PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: Mike Boyd Mike Boyd 09/29/21 01:29PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: andy eddy andy eddy 09/29/21 03:22PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: Mike Boyd Mike Boyd 09/29/21 03:43PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: andy eddy andy eddy 09/29/21 05:53PM
  Re: Puch Maxi intake airleak - having trouble finding solutionRe: roots to wings roots to wings 10/07/21 07:36PM
