Re: Vespa Malossi Fly Clutch issues
Dirty30 Dillon /
Yeah you want minimal lateral play on the input shaft, this is most easily done by setting "pre-load" on the rear cupped bearings for that shaft.
Other than that, I would suggest relieving the shoulder on the bell to reduce it's height. I have found that the aftermarket bells tend to physically bind the clutch/contra assy here, not necessarily buy friction from the seal.
