The clutch does all the things it's supposed to do eccept disengage at a stop. It seems to be dragging or something making the bike wanna take off. If you let go of the break the bike will die or take off. It's like it's always engaged. As soon as you tighten the nut and try to spin the wheel It's engaged. The bell is rubbing the seal like all the new clutches do so I sanded it a little didn't help. I am using the treats cnc bell and have also tried the malossi bell both are tight against the seal. Any ideas on this?
