Re: 47mm Puch Parma kit intake timing
> P D wrote:
> > Stephen Simmons wrote:
> > > P D wrote:
> > > Is the pin centered front to back of the piston or is it slightly
> > toward
> > > either ?
> > Which pin? The ring location pin? If so it's located where I have the
> > black mark on top of the piston.
> Sorry , I should have clarified . I meant the wrist pin . The ring pins
> are 'adjustable' .
It looks centered to me.
Looking on Google images I’m seeing a lot of reed kits ( the reed kit Probably cost as much as a good piston) but it really doesn’t fix the problem🙄 (edited)
> problem🙄
Truth. I want to fix the problem. Y s I bought the cylinder to reed it but after discovering this I'm going to play with it as a piston port.
Maybe try an airsal piston. They’re pretty cheap! Boost holes don’t affect it too much. I ran one in a metra kit for a bit, but my skirts ended up being cracked from the last seize and it didn’t last long once I took it up to 12k. (edited)
> > > toward
> > > > either ?
> the
> pins
> > are 'adjustable' .
You should measure . The pin should be , and normally is , slightly toward the exhaust side of the piston .
> slightly
> > > > toward
> > > > > either ?
> > the
> > pins
> > > are 'adjustable' .
Ill measure it
Somethiong else to consider :
How do the transfer openings in the sides of the skirt line up with those of the cylinder .
> > problem🙄
Do the opposite
Kevin Bishop /
I had a eurokit that was 47mm pp for puch on a tomos. I would check it but sold it to Tampa Steve.
Edit: never mind I forgot about the windows in the piston. (edited)
🤔 maybe?
Arisal for the win.
> Jay Rivett wrote:
> Arisal for the win.
We will see!
Guys this is dangerous stuff
Go or blow baby! To be continued....
Looking good dude. Caint wait to see your outcome.
Cleaned them up a little more.
Getting closer!
Time to order more parts
So are you gonna run a eurokit piston?
No the 47mm Parma kit with Euro kit piston
Cool I was gonna do the same but yer way ahead of me. Interested to see the results!!
> the results!!
Will definitely keep this thread updated
Working on the clutch while waiting on other engine parts
