Re: 47mm Puch Parma kit intake timing
> P D wrote:
> > Stephen Simmons wrote:
> > > P D wrote:
> > > Is the pin centered front to back of the piston or is it slightly
> > toward
> > > either ?
> > Which pin? The ring location pin? If so it's located where I have the
> > black mark on top of the piston.
> Sorry , I should have clarified . I meant the wrist pin . The ring pins
> are 'adjustable' .
It looks centered to me.
Tweaker trash /
Looking on Google images I’m seeing a lot of reed kits ( the reed kit Probably cost as much as a good piston) but it really doesn’t fix the problem🙄 (edited)
> problem🙄
Truth. I want to fix the problem. Y s I bought the cylinder to reed it but after discovering this I'm going to play with it as a piston port.
Maybe try an airsal piston. They’re pretty cheap! Boost holes don’t affect it too much. I ran one in a metra kit for a bit, but my skirts ended up being cracked from the last seize and it didn’t last long once I took it up to 12k. (edited)
> > > toward
> > > > either ?
> the
> pins
> > are 'adjustable' .
You should measure . The pin should be , and normally is , slightly toward the exhaust side of the piston .
> slightly
> > > > toward
> > > > > either ?
> > the
> > pins
> > > are 'adjustable' .
Ill measure it
Somethiong else to consider :
How do the transfer openings in the sides of the skirt line up with those of the cylinder .
Tweaker trash /
> > problem🙄
Do the opposite
Kevin Bishop /
I had a eurokit that was 47mm pp for puch on a tomos. I would check it but sold it to Tampa Steve.
Edit: never mind I forgot about the windows in the piston. (edited)
🤔 maybe?
