Yamaha Chappy lengthened swing arm
Does anyone have any information on lengthening the swing arm for LB50? I’m interested in what others may have done to get a bit better wheelbase.
Re: Yamaha Chappy lengthened swing arm
Pretty sure you would be the first man. Why?
if it's shaft drive, that seems tricky
there might be some crossover longer shaft version? like the QT50 one?
that'd be easy, otherwise, it'd be hard.
if you're one of the chain drive ones just weld in some length, get a longer chain, and party
Dirty30 Dillon /
Chappy is chain drive, but it has a very unique swingarm to incorporate the pedal mechanism. That said, why extend it? The Chappy's form factor is excellent. I miss mine heartily, although the LB50 2spd motors are not as robust as I would have liked.
Drag racing duh, can't keep the front end down
Have done it, not for particularly practical reasons but yea.
I cut the swingarm, found tubing that matched original OD & ID and got some 3mm tubing that fit the ID perfectly. Don't remember the sizes unfortunately.
welded everything together with new shock mounts. feels strong enough, hasn't bent yet but not muhc seat time
don't ask me to explain the pictures lol
is that a 3sp semi auto chappy???
i see a shifter on the left pedal... but no clutch
EH 📣FCC of the QCB /
Rear brake?
Dirty30 Dillon /
> Rear brake?
You are correct, JP's got a 3spd semi from the overseas.
