Re: Minarelli moped mod
baird co /
Chain is important. Moped have the engine sprocket inline with the swing arm pivot so the tension stays the same when you hit bumps, brake, or whatever will move the swing arm.
With the engine above it, you'll probably need some kind of spring loaded tensioner.
