Re: Single/two speed clutch fade solution ideas?
Graham Motzing /
The water pump pulley they sell for Peugeot screws into a puch crank.
Seriously though that's gonna be pulling like half a horse at 3000 rpm, you can test it out yourself with a drill and see how much torque it's pulling. They also aren't designed for an overhung load so when you hook up a belt you gotta watch the radial load.
You could buy a cheap cordless drill and mount it, I've bought the $20 hf drill for a few projects, I made a salt spreader for my ATV with one, it was the cheapest thing that could make battery power turney turn. I just zip ties the trigger down and hooked it up with a switch.
  Single/two speed clutch fade solution ideas?Topic by: Terbo Speghetti Terbo Speghetti 09/21/21 01:39PM
  Re: Single/two speed clutch fade solution ideas?Re: Mike Boyd Mike Boyd 09/21/21 01:49PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/21/21 02:26PM
  Re: Single/two speed clutch fade solution ideas?Re: Terbo Speghetti Terbo Speghetti 09/21/21 02:32PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/21/21 02:36PM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/21/21 02:49PM
  Re: Single/two speed clutch fade solution ideas?Re: Stefan Josheski Stefan Josheski 09/21/21 03:15PM
  Re: Single/two speed clutch fade solution ideas?Re: ♣Slew Foot♣ ♣Slew Foot♣ 09/25/21 04:44PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/25/21 05:46PM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/25/21 06:17PM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/25/21 06:22PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/25/21 08:56PM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/25/21 10:14PM
  Re: Single/two speed clutch fade solution ideas?Re: Probably Fred Probably Fred 09/25/21 11:03PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/26/21 01:56AM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/27/21 04:54PM
  Re: Single/two speed clutch fade solution ideas?Re: P D P D 09/27/21 05:21PM
  Re: Single/two speed clutch fade solution ideas?Re: Graham Motzing Graham Motzing 09/27/21 08:39PM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/27/21 10:18PM
  Re: Single/two speed clutch fade solution ideas?Re: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/27/21 08:27PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/28/21 12:06AM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/28/21 12:11AM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/28/21 01:19AM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/28/21 01:20AM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/28/21 01:22AM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/28/21 01:26AM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/28/21 01:29AM
  Re: Single/two speed clutch fade solution ideas?Re: Dirty30 Dillon Dirty30 Dillon 09/28/21 09:33AM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/28/21 09:54AM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/28/21 12:08PM
  Re: Single/two speed clutch fade solution ideas?Re: Aaron Blair Aaron Blair 09/28/21 03:28AM
