Re: Single/two speed clutch fade solution ideas?
Totally normal JBOT /
Did it and it worked a bit but wasn’t reliable. Electric water pumps and vacuum pumps don’t run long pumping oil. Vacuum sucks (haha) cuz it doesn’t pump when you’re ripping and vacuum drops to nothing.
To do this right, you either need to run a mechanical pump like a malossi water pump or other mechanical pump.... or run an oil sump cooled by water cooling in the sump. Basically a series of water filled cooling tubes inside that would run to an external radiator.
A massive bolt on passive billet heat sink could work as well but not as well as an active cooling setup
  Single/two speed clutch fade solution ideas?Topic by: Terbo Speghetti Terbo Speghetti 09/21/21 01:39PM
  Re: Single/two speed clutch fade solution ideas?Re: Mike Boyd Mike Boyd 09/21/21 01:49PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/21/21 02:26PM
  Re: Single/two speed clutch fade solution ideas?Re: Terbo Speghetti Terbo Speghetti 09/21/21 02:32PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/21/21 02:36PM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/21/21 02:49PM
  Re: Single/two speed clutch fade solution ideas?Re: Stefan Josheski Stefan Josheski 09/21/21 03:15PM
  Re: Single/two speed clutch fade solution ideas?Re: ♣Slew Foot♣ ♣Slew Foot♣ 09/25/21 04:44PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/25/21 05:46PM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/25/21 06:17PM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/25/21 06:22PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/25/21 08:56PM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/25/21 10:14PM
  Re: Single/two speed clutch fade solution ideas?Re: Probably Fred Probably Fred 09/25/21 11:03PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/26/21 01:56AM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/27/21 04:54PM
  Re: Single/two speed clutch fade solution ideas?Re: P D P D 09/27/21 05:21PM
  Re: Single/two speed clutch fade solution ideas?Re: Graham Motzing Graham Motzing 09/27/21 08:39PM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/27/21 10:18PM
  Re: Single/two speed clutch fade solution ideas?Re: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/27/21 08:27PM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/28/21 12:06AM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/28/21 12:11AM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/28/21 01:19AM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/28/21 01:20AM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/28/21 01:22AM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/28/21 01:26AM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/28/21 01:29AM
  Re: Single/two speed clutch fade solution ideas?Re: Dirty30 Dillon Dirty30 Dillon 09/28/21 09:33AM
  Re: Single/two speed clutch fade solution ideas?Re: * wormdirt * * wormdirt * 09/28/21 09:54AM
  Re: Single/two speed clutch fade solution ideas?Re: Totally normal JBOT Totally normal JBOT 09/28/21 12:08PM
  Re: Single/two speed clutch fade solution ideas?Re: Aaron Blair Aaron Blair 09/28/21 03:28AM
