Has anyone actually done it? I am leaning towards this cylinder for a long term build. Curious if its even possible. Im not sure of the deck height, con rod, spacer situation yet. Haven't been able to find a junk top end to play with.
Thanks for the links. Looks like they have the same rod length too. The kx seems to have a much shorter crank to base height though. I would need a longer connecting for the moby. Maybe cut down the cases. Looking like it's not really worth it
Don't bidalot and Conti make some insane cylinders for mobys?
Yes. I actually had a bidalot g1 that I sold a while back. I really regret that now. The kx65 is just something I want to do for the sake of doing.
> doing.
A old man once told me "don't ask questions UNTIL you have a problem" just do it! Especially if you REALLY want to.....
pretty common top end used for puch sprinters in Europe
Kx80 forks bolt on to a moby
I have a set on my old 50v
