Re: Peugeot 103 Manual clutch
jumpsuit steve /
i like it.
if you used a clutch with an outer pressure plate, you could push on it instead of pull. and a small hydraulic slave might do the job discreetly.
typically a clutch like the one pictured would have the actuator on the clutch side and use a lever arm or ramped plate instead of a clutch pushrod (or pullrod in this case)
