Re: Peugeot 103 Manual clutch
T y l e r /
> L e e wrote:
> So would you rotate the pedals like 90 degrees to engange/disengage the
> clutch instead of a cable?
No
Cable connected to worm gear, which would pull the entire pedal shaft to the right. The end of the crank arm would then disengage the clutch.
