Re: Peugeot 103 Manual clutch
L e e /
> T y l e r wrote:
> My friend Shaw took a motorcycle clutch, welded to an angel pulley
> (solid alu), then used a worm gear over the pedal shaft to engage it.
> Pug rear manual clutch worked perfect, simple design, but genius.
So would you rotate the pedals like 90 degrees to engange/disengage the clutch instead of a cable?
