puch kitted rpms?
my trusty old puch nostalgia.
I know it has the bushing crank just wondering if I'm pushing my luck...has a 14 bing, techno pipe and airsal 70 kit.
I while back my wife and her friends went bar hopping and the friend riding the puch was struggling on hills...I swapped out the gearing from a 17 front to a 15 front and it is lots peppier on hills but when i wind it out I fear the bushing is taking a beating.
I have a digital tach and when i was riding around the other day i was surprised at how high the rpms got (12-13K).
I know that's bad but was wondering what is considered a normal rpm for a kitted puch. It doesn't get pushed much (except by me)!
I've heard 8500 rpm is about your limit for bushing cranks before they start to go bye bye...
Thanks!
Re: puch kitted rpms?
That kit and pipe probably are not hitting that high rpm. Is your tach adjusted right? Check out moped toolbox you can put in your gearing and speed to get a aprox rpm.
I had a similar setup with a shitty crank and literally blew up my motor, the crank blew through the cases at aprox 10,500 rpm at around 380 degrees.
So yes, on a stock crank you are going to want to put that 17 up front again at least until you can validate your tach or rebuild your bottom end. If you stay under 8500 rpm you are fine. (edited)
Probably Fred /
Your digital tachometer is set on 4 stroke silly So your RPMs are half of what it shows Because it’s showing 2 revolutions for one spark so set it for two stroke
Matt Madden /
Yah that’s what I was thinking but it’s definitely set on 1p1r….
Just seems nuts that it’s spinning that fast…think it’s getting interference from a non resister plug?
Also idle is sitting at around 1100 which seems kinda right
I’ve used Marty’s garage for gear ratios and if I was pulling those kinda Roma I should be doing like 50…which I know it isn’t
Thx
roots to wings /
The advice I’ve received in this forum as I understand it is that a stock crank will die with a kit if you constantly ride at the edge of the rpm range. My airsal 65 at 16x40 with the right clutch, clutch jetcand wheel bearings needed to be in motion to hold on good sized hills. At 15x40 it rips hills has great torque and still goes over 40 which is good for me. In not riding 40 for miles on end. I like to stay in the 35-39 range
Johnny Braaapp /
My hogged out polini spins 5 digits 1/2 throttle boi
Yeah generally accepted max sustained rpm on a stock crank is 8k. I ran one up to 9500 pretty regular for a couple years but it eventually just wallered out. Use the gearing calc, I like 16*45 on that setup or there about. Most people barely break 45 on those.
Matt Madden /
Yeah, I like the pull with the 15/45 but top end could be better…I’m thinking it might hit 40+ but when I saw those rpm’s climbing like that I was like “whoa “!!!
Like I said I had a 17/45 on it and it was pretty slow off the line and on hills…top speed was pretty fun tho’ lol
So down the road I guess a new crank would be prudent (maybe this winter!)
When the bushing crank goes bye bye what can I expect? Busted crank or just no go no mo?
Thx!
Probably Fred /
> Thx
No the idle is probably about 2K so it’s still wrong, techno circuit is a crank saver it won’t rev much past 8.5k with a piston port kit/cylinder
Matt Madden /
What could possibly be wrong with the tach?
Just a shitty one?
If the pipe won’t let it rev out that much should I not be concerned?
Marty’s garage seems about right as far as the gearing/speed seems so the revs should be pretty spot on too correct?
Thx
Do a GPS run with your phone and use Martys calc to find your rpm. If you are only going 40 on 15x45 you're fine but that's pretty lame for a 70 kit, might need to do more tuning.
Crank and a rebuild is always a good investment. Peace of mind if nothing else but if it's really running that poorly you might find some other problems that are holding you back. Take some time over the winter and check brakes (dragging?) wheel bearings, tires, chain, etc. You might find the 5 or so missing mph.
I've run lots of these kits, 16x45 is the magic number. You will go exactly 46 and get there nice and quick with good accel. Anything less you have problems.
Probably Fred /
> you have problems.
I don’t know what magic number you’re talking about but for a techno circuit pipe 16x45 Gears is not the magic number
That’s over 10,200 RPM for 46mph and actually from seeing a running a tachometer it’s more like 10.5k to get 46mph. I never got 10.5k rpm out of a circuit pipe with a simple 70cc kit bing setup.
A circuit pipe is about 8.5K so 17×40 gears is the magic number for 45-47mph and even 16x40 is about 42-43mph, They both are pretty close and you basically only need thick springs in your clutch, nothing fancy like higher rpm pipes need.
The tecno circuit pipe is so torquey that you could go just as fast as Boss or bullet pipes with lower RPM even though it doesn’t feel as fast as those pipes because even though it’s not screaming as much it is just as fast.
I did dozens of 70cc kits with 14-15mm bing and circuit pipes, Like I said with its lower rpm power it’s a crank saver and it’s perfect for a stock crank engine whereas a bullet or Boss pipe can ruin it (if you’re tuned correctly for those pipes to rev out) as well as needing a better tuned clutch to get into the higher powerband they have
Matt Madden /
Well there seems to be some disagreement but that’s mopeds right?
I’ve been running the techno, 70 kit 14 bing for years (not a daily rider) and it’s been fine. I like the 16/45 combo but I really like the extra pep up hills with the 15…anyway, my tach is probably shit so who knows what I’m running rpm wise…
Speed runs are generally pretty short around in the suburbs here
And a new crank probably wouldn’t hurt…but it probably won’t get abused that much
Almost all my pads could go faster if I moved to sea level instead of 5280
Thx for the feedback!
I like 17*40 with a 70 kit,bing and circuit. tire size will also affect rpms if I'm not mistaken. Here is some screen shots from the excel sheet I use for gearing
I've only been able to get a little over 7k RPM from a circuit pipe. The techno estoril pipe get a little over 9k. I wish either one of those would rev out to 12k RPM!
Matt Madden /
Just. curious
What tach iis everything be using?
No tach needed. Just gps ur speed and calc based on gearing
Few digital tachs I've tried are weird. Bounce all the place. Noise in the coil wire maybe? (edited)
Matt Madden /
Any formula?
Thx
Tecno estoril or circuit? The estoril will over run to just over 10k, I don't see where it says that it's a circuit but yeah that's wrong if so.
Matt Madden /
It’s a techno circuit…
Oh sorry yeah nevermind then, you're good, 16*40, stock crank, tune clutch. Ken roff special. Don't fly too close to the sun melt your crank bushing like Icarus.
Matt Madden /
Haha
Thx, I just went out and did my gps run…top speed was 41.1 with a stop sign looming…lol
So with 15/45 techno circuit, bing 14 and tuned clutch the verdict seems to be I’m spinning at 9711 rpms according to Marty’s garage.
In the danger zone if I keep it up for too long I suppose
I gotta say the WOT is pretty rare…I do love the way it climbs with this gear ratio tho’
kim jensen /
Use the puch gearing/rpm calculator .
GPS your top speed, then check that on the gearing chart to determine what rpm you are hitting. Doubtful you are hitting 12K.
And yes I would recommend a Rito needle bearing crank if you plan on running 9k or more for very long.
Matt Madden /
Thx!
Yeah, the digital tach I have must be garbage.
Maybe I’ll try it on my motorcycle but that is definitely not anywhere near redlining haha
Regarding the tecno circuit pipe topping around 8.5K rpms....then please explain why mine revs out to 9,400 rpms according to Marty's calculator. 70cc piston port treats kit on e50 1978 Newport, no case match, tecno circuit pipe, 12mm bing with modified stock airbox, grandpas 15mm intake, 64 jet single ring needle clip on 2nd leanest notch, 15X45 gearing stock wheels/rims. 38-39 mph verified by phone speedometer gps on flat roads. Running temp gauge temps mostly in mid 200s sometimes very low 300s on sustained WOT runs for 5+ miles (between 305 and 335 degrees tops even after bombing up a long 1/2 mile hill). So the circuit pipe can hit 9,400 rpms on flat roads and remember I'm rocking only a 12mm bing with modded stock airbox
The numbers cited are 'peak torque' rpms, i.e. if you are geared out for top speed the kit will kinda peak out at around that rpm. Yes you can gear shorter, and it will rev higher like revving on the stand, there is less load on the engine. Then you have the added bonus that it will get deeper into the torque curve as you slow down and will pull out of the hole. If you gear way out, as soon as you start to slow down on a hill you will drop off more speed since your torque goes down.
Those techno circuit are kinda weird, on some setups they hit a second resonance point higher up and they just scream, some setups just choke and don't run for shit.
