Re: Malosi reed block tuning
kim jensen /
No worries Graham.
Yeah tru dat on worn points retarding.
Going to have to recheck that stator. Going to upgrade the lighting coil anyways.
I do use a timing light to verify what the setting is. Maybe I'll try a timing wheel as well.
Jetting has cooled down cruising temps, but any hard acceleration jumps temps too high. I ran an 84 main with the Malossi block for several years. Now going to try 86 again with the flat reed, but I think it will four stroke.
Anyways going to port the intakes, cut the fins, put on the Malossi and new Polini head and start over. Mopeds.
Thanks for the cam lube tip!
