Hey guys, have a variated Ciao and I'm trying to find proper belt length.
I have a Polini variator with a Euro clutch on the back with 90mm pulleys to fit into the Ciao frame without cutting it up. The 7227 Malossi Ciao belt is waaay too loose, I'd need to extend the engine mounting holes in the frame at least 10mm more each than it's already been lengthened to get it taught enough to work, is there a different belt y'all are using that would work?
TIA
