studs might need relocating? i cant imagine 56mm bore would have the same stud spacing. plus a 49mm stroke crank would be required. doubt the std rgv would have the tapers to accept the moby clutch and ignition. its doable i suppose. plus a bit easier if you have access to a machine shop.
