> Jay Rivett Wrote:
> If your engine a horizontal or vertical cylinder? Horizontal garelli
> bikes are NOI engines, and the vertical cyl are the VIP. VIP engines
> came in a few speed transmission option, but never single speed. You
> should most likely have a 2 speed automatic if it is a VIP engine.
Tangentially, Avanti made VIP clones, and they did produce a single speed version (the Avanti Mont). There's also the motor on the Monza, which looks like a VIP, but isn't (different crank), and is single speed.
> Fortunately this should not matter for what you are trying to set up.
> However you could make things a little easier and just get a vip 12v cdi
> ignition from moped division. I just saw all the bits you would need
> for sale on their site. You would just replace the whole plate with the
> new cdi plate and add in the cdi box they sell. Your current HT coil
> should work for the cdi.
I'm not sure what parts you're referring to here. I think you might mean the Avanti CDI setup, but I think that requires a different flywheel: https://www.mopeddivision.com/moped-make/avanti/electrical/nos-avanti-12-volt-40-watt-cdi-flywheel-stator-plate-5-wire/
