Re: Treats puch sealed wheel bearings
Mike Boyd /
You'll need a center spacer for the hub between the new sealed bearings as well. The last time I did a Puch Leleu spoke conversion I ended up using a 76mm spacer, but you must measure your own to get the right spacing.
You can mix and match the spacers in this kit to get the correct spacing, but it's better to get a length of steel pipe with an ID of just over 12mm and an OD of 17mm or so and cut it to size based on your measurements.
You may also need a 12mm drill bit for the brake hub
