Re: Nasty dirt ped build with a touch of COVID & another stuff
Dirty30 Dillon /
First: It's pretty proven at this point that swinging motors bike are one of the hardest to dirt-ped, simply given the fact that you have bouncing terrain, which causes your motor to dangle, pulsing and slipping the belt. You can get away with a light (compact) moby or pug motor by doing a gas strut, but that heavy scooter case with all that counter weight is gonna cause issues.
Second: what are doing about the clutch? Currently you have no way of clutching the bike, so you either are going to set your belt to be slack at idle, which means you won't move until the cheeks close onto the belt (losing lots of variation) or you're going to attempt to run it with a clutch and suffer from some pretty poor take-off.
Last: Your hanger mount is not going to function as it sits. It definitely needs to be triangulated to stop double-hinged swinging, and to stop it from just rotating itself off.
Paint looks cool, although why you painted prior to getting the engine spring mounts, etc. finalized is a mystery. Have fun, maybe it will work in the end?
  Nasty dirt ped build with a touch of COVID & another stuffTopic by: 666 420 666 420 09/05/21 03:16PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: LSLB RXb LSLB RXb 09/06/21 12:36PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/06/21 02:31PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/06/21 07:39PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/09/21 11:25PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: L e e L e e 09/13/21 09:39PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: Dirty30 Dillon Dirty30 Dillon 09/14/21 09:00AM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: Graham Motzing Graham Motzing 09/14/21 09:58PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: Dirty30 Dillon Dirty30 Dillon 09/15/21 08:50AM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: Graham Motzing Graham Motzing 09/15/21 08:24PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: Dirty30 Dillon Dirty30 Dillon 09/15/21 09:09PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: Totally normal JBOT Totally normal JBOT 09/15/21 09:20PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/15/21 09:23PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/15/21 10:25PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/17/21 05:53PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: Born to be WillD Born to be WillD 09/23/21 10:04AM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/23/21 03:24PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/23/21 07:13PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: MR Aerox MR Aerox 09/12/21 05:22AM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/13/21 01:55PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: Totally normal JBOT Totally normal JBOT 09/13/21 03:41PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/13/21 08:36PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: Graham Motzing Graham Motzing 09/13/21 10:20PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/14/21 01:16AM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/14/21 01:17AM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: * wormdirt * * wormdirt * 09/17/21 07:07PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/18/21 02:29AM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/19/21 12:35AM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/19/21 04:52PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: Buttcheeks BUZZARD Buttcheeks BUZZARD 09/19/21 10:11PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/20/21 02:39PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/22/21 03:17PM
  Re: Nasty dirt ped build with a touch of COVID & another stuffRe: 666 420 666 420 09/22/21 03:39PM
