Ok I want to start off by saying yes I know this is probably a bad idea and that I'm crazy for trying it, now with that out of the way, is this possible?
I already have a rough plan in mind using one of those little small engine nitrous kits such as this
https://www.amazon.com/dp/B01L4E4R7M/
I don't have very much skill as far as nitrous systems go but I know the gist. I know that you need to add more fuel to compensate the extra air, I have a dellorto phbg 19 on my motor right now, I was thinking that since dellorto chokes inject more fuel when used instead of blocking off air I could tune the choke circuit to compensate fuel that way I can just pull the choke while using nos
I was planning on attaching the nitrous feed tube to one of the vacuum ports on the carb.
I know that nos will put much more extra strain on the motor but each of those little cans only have about a 10 second shot in them, do you think my motor can handle it? I have a Doppler full circle crank, an airsal 74cc kit with a 74cc polini head, mallossi intake and reeds, treats cdi, and a gianelli exhaust if that info helps.
I don't know if this is even feasible, but what do you guys think?
