Re: Polini CP 17.5 Guidance on Puch Polini 64cc
Michael Jones /
Thanks again for all the great advice.
-The bike idles on the stand well and I have checked for leaks with carb cleaner. I did thorough breaking in on the old Bing 12.
-The rear sprocket has 52 stamped on it. If it's actually a 45, whoever stamped that 52 is missing out on the punchline. My front sprocket I swapped in is a 18, not 19T. So it puts me close to the stock ratio.
-I let the cylinder break in idling on the old Bing and putt putts around the block for several days. I'm still avoiding constant throttle etc.
Does one need to Run break in cycles every time after pulling the head? I have replaced all the gaskets and I think she is pretty tight. Didn't deck the head or anything, but I use a torque wrench.
-Today I mixed up and loaded some 60:1, about half the oil than I had been running during break in.
-I ordered a temp/RPM gauge, lesson learned.
It seems to sound a little better on the stand running the spec oil mixture and the taller gear. I didn't have the opportunity to test ride much, but it kind of felt like it did the trick putting redline further out of reach may have been all I needed, but waiting for the sensor.
I did some calcs and I was probably going up to 10K rpm when I had that soft seize. I'm waiting for the rpm/temp gauge to come in before giving it the beans.
Taking a closer look at the timing is on my list. With the temp sensor, if I adjust my timing, can I look for a temp difference at idle or would it only show running a route and watching temps?
  Polini CP 17.5 Guidance on Puch Polini 64ccTopic by: Michael Jones Michael Jones 09/02/21 01:18AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: baird co baird co 09/02/21 12:08PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: tom wizard tom wizard 09/02/21 05:19PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: First Name Last Name First Name Last Name 09/05/21 01:47AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Graham Motzing Graham Motzing 09/05/21 01:33PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: b to the eff b to the eff 09/02/21 07:57PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: First Name Last Name First Name Last Name 09/05/21 01:52AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Stephen Simmons Stephen Simmons 09/05/21 08:23AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 09/08/21 01:41AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: baird co baird co 09/08/21 12:53PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 09/08/21 01:56AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 09/08/21 02:12AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Jay Rivett Jay Rivett 09/08/21 10:48AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Graham Motzing Graham Motzing 09/08/21 11:34AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 09/09/21 12:43AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: baird co baird co 09/09/21 11:23AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Graham Motzing Graham Motzing 09/09/21 11:42AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 09/09/21 04:09PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Graham Motzing Graham Motzing 09/09/21 04:43PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 09/11/21 06:20PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Mike Boyd Mike Boyd 09/22/21 11:10AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 09/12/21 10:50PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 09/22/21 12:39AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 09/22/21 11:48AM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Mike Boyd Mike Boyd 09/22/21 12:00PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 09/26/21 10:06PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 10/21/21 10:06PM
  Re: Polini CP 17.5 Guidance on Puch Polini 64ccRe: Michael Jones Michael Jones 11/17/21 10:03PM
