> Nick Johnson Wrote:
> I've got my stocker running good and now looking to modify things. I
> have an e50, 15 bing, 15 intake, high flow air filter, and a circuit
> pipe. Any ideas on starting jet or range? Thanks all in advance!
What cylinder? aluminum, high torque, one HP, 1.5 HP-two HP, Real bing carb?
Most real 15mm bing carb, 217 atomizer with two HP aluminum square port cylinder with Metal high flow filter will be around 78 jet
But timing comes before jetting so make sure your magneto is serviced and timed correctly
