Re: Which 70cc Kit From Treatland Should I buy?
Thomas Peffer /
^Yes the kit shown above from Dos Cycles is a really excellent kit and reasonably priced. The Puch 70cc treats for the people Version 1 piston port kit I've also been having surprisingly good results with. You must run synthetic oil at 2% because all newer kits in general are poorly cast nowadays you need max protection especially during break in and you must time low (do not do what I did a year ago on a previous Maxi I used to own and time high because you will run too hot and seize quick) and above all run a temp gauge. Yes the temp gauge is $50 but it can save you and your new kit a lot of grief! Chamfer your ports and gap your ring to around .014" to .015"
  Which 70cc Kit From Treatland Should I buy?Topic by: Michael Romco Michael Romco 08/25/21 04:15PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Mike Boyd Mike Boyd 08/25/21 04:35PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Probably Fred Probably Fred 08/25/21 09:16PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Thomas Peffer Thomas Peffer 08/26/21 09:04AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Jay Rivett Jay Rivett 08/26/21 10:42AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Graham Motzing Graham Motzing 08/26/21 10:54AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Steve Paul Steve Paul 09/16/21 10:08AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Graham Motzing Graham Motzing 09/16/21 12:53PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Cam Haley Cam Haley 01/02/22 09:52AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Alan Jackson Alan Jackson 08/26/21 01:49PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Graham Motzing Graham Motzing 08/26/21 04:59PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: lucien vogin lucien vogin 08/30/21 02:40AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Michael Romco Michael Romco 08/26/21 11:02PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Graham Motzing Graham Motzing 08/27/21 12:20AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Thomas Peffer Thomas Peffer 08/27/21 07:48AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Michael Romco Michael Romco 08/27/21 01:02PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Alan Jackson Alan Jackson 08/27/21 02:40PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: * wormdirt * * wormdirt * 08/28/21 12:55AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Graham Motzing Graham Motzing 08/29/21 10:25AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Daniel '' Daniel '' 08/29/21 11:11AM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Graham Motzing Graham Motzing 08/30/21 05:00PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Aaron Ward Aaron Ward 08/30/21 05:12PM
  Re: Which 70cc Kit From Treatland Should I buy?Re: Satan 666 Satan 666 09/16/21 11:14AM
