Modded FA50 vm18 jetting
I understand that jetting advice is free and worth every penny you pay for it lol. But I would like to pick your brains as to what range of jetting is normal for a setup similar to mine.
The bike
89 fa50
Treatland big bore kit
Shaved head
Ported reed block
Boyesen 2 stage reeds
Vm18 carb
MLM intake
LeoVince pipe modded from some other moped
Stock timing
Deleted oil injection 50-1 premix e0 fuel
Right out of the box I lowered the float level. It was far too high as shipped for the angle my intake sits at and flooded immediately.
I know the idle jet is too big because I’ve got a lot of turns on the air screw and the choke is unusable. I’ve got an assortment coming.
The clip is second from bottom and the bike runs well enough. Perhaps a little soft on bottom but it’s very strong about 20mph and tops out at 30. It’s a little bubbly sounding at steady state cruise around 1/2 throttle. 3/4 to WOT doesn’t seem to net any extra acceleration or speed
Mainly want your opinion if this current tune is safe enough to get some miles on the moped and really dig into dialing the jetting in. (edited)
Re: Modded FA50 vm18 jetting
Any changes to the jets? IMO the stock 70 is usually too lean and the 30 idle is too rich for most bikes, but idk how your hack n weld one off FA is gonna run. I’d say if youre worried about seizing (and you should be w/ that kit) go rich all around (prolly like 95 main and keep the 30 idle) and work your way down. Better to foul a plug than seize right? HFFS on the wiki man
I like your rear disc conversion. I bet helps stop it a lot better. I wish I had better brakes on my QT’s.
Can you share the process how to convert to the rear brake disc ?
