So if you’ve seen my posts on here for years you’ll know that I’m not a huge fan of V1’s. There are a number of reasons for this but the #1 problem I have with them is the clutch. I don’t like a lot of things about the design but mostly I don’t like the weak starter clutch arrangement, I don’t like how the clutch shoes themselves are setup, and I really don’t like the riveted pin design that I’ve seen fail numerous times. I’ve never really dug that deep into them, but I’ve built a couple with the big PP kits over the years and I was always frustrated that I couldn’t get the clutching to behave in a way that I thought was acceptable.
Fast forward to a few months ago, I started working on a V1 based cylinder project with Blake @ Dos. I got to the point where I need to test this setup so I picked up a motron for cheap and I got a Kickstart engine from DOS to solve the starter clutch problem, a roller taper crank from DOS to solve the stub-plane crank problem, and after posting THIS THREAD a couple people hit me up and told me to check out the Botanas V1 clutch at Dos Cycles
Since there isn’t much info out there on it, I wanted to start a thread to show what this clutch is about and get some feed back from anyone else that’s run it.
Here is the clutch in question
Its roughly a ‘ktm design’ with 3 shoes on a triangular center hub, similar to the ktm a single bolt secures the shoe to the hub with a spring.
The back side has a flat plate which will allow you to run it with pedal start. It’s a machine finish so it should grip pretty good but you might still want to rough it up a bit.
The starter plate means that the whole clutch is narrower, the shoes are narrower and therefore have a smaller hole for the bolt.
