Re: Proma or Tecno circuit for magnum
Totally normal JBOT /
Set your timing and things up like that and then you can just slip an estral pipe on there and probably Cruise 45 all day.
You will need to up jet some and might need to change the needle
Bring your timing down to 17° when running the expansion chamber.
And you will probably need to do a little filing on the bottom of this slide to adjust the idle mix.
Just look up the old crazy Wayne profile with all the links and information.
  Proma or Tecno circuit for magnumTopic by: Erin L Erin L 07/31/21 06:07PM
  Re: Proma or Tecno circuit for magnumRe: Sir Clip Sir Clip 07/31/21 06:12PM
  Re: Proma or Tecno circuit for magnumRe: Probably Fred Probably Fred 07/31/21 08:09PM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 07/31/21 08:14PM
  Re: Proma or Tecno circuit for magnumRe: Erin L Erin L 07/31/21 09:17PM
  Re: Proma or Tecno circuit for magnumRe: Graham Motzing Graham Motzing 07/31/21 10:11PM
  Re: Proma or Tecno circuit for magnumRe: Erin L Erin L 08/01/21 08:47AM
  Re: Proma or Tecno circuit for magnumRe: Graham Motzing Graham Motzing 08/01/21 09:36AM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 08/01/21 10:41AM
  Re: Proma or Tecno circuit for magnumRe: Full Tuck Full Tuck 07/31/21 11:31PM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 07/31/21 11:38PM
  Re: Proma or Tecno circuit for magnumRe: Erin L Erin L 07/31/21 11:49PM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 08/01/21 02:14AM
  Re: Proma or Tecno circuit for magnumRe: Graham Motzing Graham Motzing 08/01/21 09:38AM
  Re: Proma or Tecno circuit for magnumRe: EH FCC of the QCB EH FCC of the QCB 08/01/21 10:13AM
  Re: Proma or Tecno circuit for magnumRe: Erin L Erin L 08/01/21 11:23AM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 08/01/21 12:05PM
  Re: Proma or Tecno circuit for magnumRe: EH FCC of the QCB EH FCC of the QCB 08/01/21 01:22PM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 08/01/21 01:44PM
  Re: Proma or Tecno circuit for magnumRe: josh n josh n 08/09/21 02:58AM
  Re: Proma or Tecno circuit for magnumRe: Probably Fred Probably Fred 08/09/21 04:53PM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 08/09/21 05:04PM
  Re: Proma or Tecno circuit for magnumRe: josh n josh n 08/09/21 07:38PM
