Re: Proma or Tecno circuit for magnum
Graham Motzing /
Yeah probably more work than it's worth to make the magnum kit adapt, you'll have to cut off the header, buy or make a flange, cut and weld the flange on the header and weld the header back on. The proma also needs the 3rd mounting point that attaches to a head stud, so it's extra tricky to line up.
TBH the magnum stock exhaust is already pretty good, it's not a chamber pipe but it does have really good low end. If you can bump the compression a bit, 15 bing, and tune the clutch it makes a really solid 35 mph bike with good torque. Megan bandit had that setup on an orange pinto back in like 2006 that absolutely murdered hills and got up to 40 with a quickness
  Proma or Tecno circuit for magnumTopic by: Erin L Erin L 07/31/21 06:07PM
  Re: Proma or Tecno circuit for magnumRe: Sir Clip Sir Clip 07/31/21 06:12PM
  Re: Proma or Tecno circuit for magnumRe: Probably Fred Probably Fred 07/31/21 08:09PM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 07/31/21 08:14PM
  Re: Proma or Tecno circuit for magnumRe: Erin L Erin L 07/31/21 09:17PM
  Re: Proma or Tecno circuit for magnumRe: Graham Motzing Graham Motzing 07/31/21 10:11PM
  Re: Proma or Tecno circuit for magnumRe: Erin L Erin L 08/01/21 08:47AM
  Re: Proma or Tecno circuit for magnumRe: Graham Motzing Graham Motzing 08/01/21 09:36AM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 08/01/21 10:41AM
  Re: Proma or Tecno circuit for magnumRe: Full Tuck Full Tuck 07/31/21 11:31PM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 07/31/21 11:38PM
  Re: Proma or Tecno circuit for magnumRe: Erin L Erin L 07/31/21 11:49PM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 08/01/21 02:14AM
  Re: Proma or Tecno circuit for magnumRe: Graham Motzing Graham Motzing 08/01/21 09:38AM
  Re: Proma or Tecno circuit for magnumRe: EH FCC of the QCB EH FCC of the QCB 08/01/21 10:13AM
  Re: Proma or Tecno circuit for magnumRe: Erin L Erin L 08/01/21 11:23AM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 08/01/21 12:05PM
  Re: Proma or Tecno circuit for magnumRe: EH FCC of the QCB EH FCC of the QCB 08/01/21 01:22PM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 08/01/21 01:44PM
  Re: Proma or Tecno circuit for magnumRe: josh n josh n 08/09/21 02:58AM
  Re: Proma or Tecno circuit for magnumRe: Probably Fred Probably Fred 08/09/21 04:53PM
  Re: Proma or Tecno circuit for magnumRe: Totally normal JBOT Totally normal JBOT 08/09/21 05:04PM
  Re: Proma or Tecno circuit for magnumRe: josh n josh n 08/09/21 07:38PM
