Pietcard 3055/2041 timing help
Having trouble timing my Pietcard 3055/2041 combo on my ZA50.
Using a timing light to find the firing mark with a drill, then setting it to 1.8mm BTDC using a buzzeti tool and then placing the flywheel on the firing mark. It starts up and idles kinda ok but kinda poo, but has absolutely zero power and won’t rev up at all, like not enough to even move the wheel. The bike was running fine on the previous setup so I don’t suspect any other issues.
I have the pietcard facing lettering OUT towards the flywheel (wired behind). I have the original ZA #44 flywheel.
When I check with a timing light on this wonky idle the timing is jumping everywhere. Seemingly barely even close to where it should be …
Re: Pietcard 3055/2041 timing help
campeona del mundo /
are you using the pietcard ht coil?
Jacob Fulton /
No, using the stock HT coil
get the pietcard ht coil. i've had good luck running "full" pietcard setups (ht, cdi box, and internal coil).
i've been rocking the olympia coil on my pietcard setups, they seem to work quite well too
Ya dude get a new coil. I think that is the problem. Also using a drill will not get you accurate timing. I will spin too slow. It will get you close enough but you will probably have to adjust.
🇮🇹💦 Of the Loin /
Just curious, what is the resistance in ohms of the "pietcard coil"
That is all that matters in this circuit.
I assume your current coil is outside of spec
Jacob Fulton /
I have a Pietcard ht coil on order. I have been in contact with someone who has ran this exact setup with the stock coil which is why I’ve been trying to use it. That being said if this doesn’t fix it I think I’ll just call my loss and go HPI, which I’ve ran successfully on my other bike.
Mattman MopedHead /
I just got done kinda figuring out this combo. I set mine up on an E50, starting first with the 2013 box. In my experience, if it idles but will not rev, flip the flywheel 180°. It's wanting to run backwards, but it fired up forwards, cause that's how it is.
Set it exactly opposite of where the woodruff key would go. Figure out your fire mark again and set it up as you had it.
It clicked for me when one time I started and it kicked back and ran backwards. And it rev'd! So many times of just idle, no power, no rev. Hope this helps.
^^^^^this. The pietcard coil swap on the stator plate does not allow the original position of the stator to place the firing points at the correct timing. You will need to remove the woodruff key from your flywheel and reposition it to where the timing needs to be. Check out the wiki for steps on it. Pretty easy to get set up.
Totally normal JBOT /
Did you try swapping the lighting coil location with the Pietcard location.
🇮🇹💦 Of the Loin /
I'm just curious
CAN someone ohm out a pietcard HT coil and post the value
Jacob Fulton /
Threw the Pietcard ht coil on today, no change sadly. Spent an hour trying basically every position and combination the flywheel could fit on, coul flipped in and out, it either backfires / sputters or does the wonky idle with no rev.
Bring up here and we'll get it goin ;)
Jacob Fulton /
I made a quick video before today’s rage quit showing the motor running at idle with various timing marks 1-5.
In the video I’m using the stock key position. I’ve tried timing to various of the marks like I would my hpi but womp womp.
Edit: YouTube destroyed this video, can barely see shit (edited)
🇮🇹💦 Of the Loin /
Can you make a resistance measurement of the pietcard coil vs a regular coil?
Jacob Fulton /
I can next time I’m out in the garage
The video looks halfway normal there are more than one magnet in the flywheel there for each one will create a flux across the winding.
And depending on the rotation of the motor the magnets can be reversed in there mounting to the flywheel.
Remove the flywheel and drag a small magnet over the flywheel magnet if you have cracks in the magnetic material in your flywheel that will create additional flux peaks in the flywheel that are much weaker due to the smaller pieces of magnet I suspect you dropped your flywheel and cracked the magnets (edited)
Jacob Fulton /
I have a spare za flywheel I can try using before this goes in my parts bin.
Jacob Fulton /
Threw a el cheapo cdi (with the gold flywheel) on with the Pietcard 2041 and ht coil and I’m ripping. Finally! (edited)
And you're probably noticing that it only has one point at which it is firing the ignition.
And if you had looked closely inside that flywheel you would have seen that it was One singular magnet wrapped all the way through the flywheel.
Rather than the four magnets in the normal Bosch ZA E-50 flywheel but yours was probably more like 10 because of all the shattered magnetic material causing multiple flashes on your timing light (edited)
🇮🇹💦 Of the Loin /
And yet still no resistance measurement
