Having trouble timing my Pietcard 3055/2041 combo on my ZA50.
Using a timing light to find the firing mark with a drill, then setting it to 1.8mm BTDC using a buzzeti tool and then placing the flywheel on the firing mark. It starts up and idles kinda ok but kinda poo, but has absolutely zero power and won’t rev up at all, like not enough to even move the wheel. The bike was running fine on the previous setup so I don’t suspect any other issues.
I have the pietcard facing lettering OUT towards the flywheel (wired behind). I have the original ZA #44 flywheel.
When I check with a timing light on this wonky idle the timing is jumping everywhere. Seemingly barely even close to where it should be …
