78 Honda pa1 carb question
Steven Bolduc /
I have a stock pa, 50-1, I have a vm20 carb
And custom intake from treats and that
I would like too know if I can jet it down
And get it too run good? Or should go back too original carb. The mlm intake are new I just ran it for a minute. Thx in advance steven.
Re: 78 Honda pa1 carb question
Are you using the stock reedblock? PA50i's are sooooooo restricted that I am still baffled by the VM20 on this one. If you got it to run and ride at all as is I'd be shocked
Steven Bolduc /
Yes the original reed block, but treats said
It would work for pa1-,pa2 kitted or original. I have PA 2 motor ln a parts bike
That I should have used.
> parts bike
I mean it will work, but it just doesn't really make a ton of sense for you to do. The stock carb is 10mm. The stock reedblock/reeds is a single reed pedal. If you had swapped reedblocks and exhausts you could probably get it to run with a stock cylinder. But a combination of reeds, exhaust, and cylinder restrictions make it difficult to tune such a huge carb.
I ran my pa50i hobbit with a DR kit, proma pipe, pa50ii reedblock and TJT variator with the stock 10mm carb without much issue. I eventually put a 19 PHBG on it but still; carb upgrade is usually the last thing on the checklist in terms of performance
Steven Bolduc /
I'm putting on a sh, and put the other setup on my pa2.
