Yeah the za intake will definitely need you up, you'll probably also want to add some gear, it will delay the second great shift a bit and won't hurt accel as much as you think.
Those circuit pipes are done at 9k, really don't make much power above 8k. Crunch your numbers hitting you top speed at 45mph and go through brakes, chain, tires to make sure nothing is holding you back
