Re: Building a ZA50.
Probably Fred /
If it’s dying with full throttle that has nothing to do with the condenser
If it’s dying with full throttle could mean it’s choking itself out probably due to the incorrect atomizer/needle jet and possible needle and other incorrect made parts a clone carburetor has.
You could have a fuel flow problem at full throttle, do you have an in-line fuel filter?
You didn’t state what kind of air cleaner you have on there either.
If it’s stock then it will run too rich with that jet you should try with no air cleaner or a metal mesh filter,
You do know that the treats kit is not base spaced correctly so the piston is covering up some of the ports as well as piston and ring is in the exhaust port,
You also didn’t state what your timing was set at or what your head temperature gauge says as well as what your gearing is,
If you have short geared sprockets 33 mph could be very high rpm
The gearing chart on here could tell you what your bike mph is at any given RPM after you put in correct the information (sprockets, tire size etc) https://toolbox.martysgarage.info/
If you give all the information it’s more easy to diagnose problems
  Building a ZA50.Topic by: Taylor King Taylor King 06/13/21 10:47PM
  Re: Building a ZA50.Re: * wormdirt * * wormdirt * 06/13/21 11:00PM
  Re: Building a ZA50.Re: Taylor King Taylor King 06/13/21 11:36PM
  Re: Building a ZA50.Re: Jacob Fulton Jacob Fulton 06/14/21 01:39AM
  Re: Building a ZA50.Re: juliy wann juliy wann 07/10/21 09:59AM
  Re: Building a ZA50.Re: Jay Rivett Jay Rivett 07/10/21 12:51PM
  Re: Building a ZA50.Re: juliy wann juliy wann 07/11/21 02:26PM
  Re: Building a ZA50.Re: Alex Fredericksen Alex Fredericksen 07/11/21 07:52PM
  Re: Building a ZA50.Re: Graham Motzing Graham Motzing 07/30/21 07:52PM
  Re: Building a ZA50.Re: Richard Eberline Richard Eberline 07/11/21 06:43PM
  Re: Building a ZA50.Re: Taylor King Taylor King 07/14/21 04:38PM
  Re: Building a ZA50.Re: Probably Fred Probably Fred 07/14/21 06:22PM
  Re: Building a ZA50.Re: Taylor King Taylor King 07/14/21 10:24PM
  Re: Building a ZA50.Re: * wormdirt * * wormdirt * 07/15/21 12:04AM
  Re: Building a ZA50.Re: Taylor King Taylor King 07/15/21 08:53AM
  Re: Building a ZA50.Re: Probably Fred Probably Fred 07/15/21 10:05AM
  Re: Building a ZA50.Re: P D P D 07/15/21 11:51AM
  Re: Building a ZA50.Re: Alex Fredericksen Alex Fredericksen 07/15/21 12:04PM
  Re: Building a ZA50.Re: Taylor King Taylor King 07/18/21 02:09PM
  Re: Building a ZA50.Re: Taylor King Taylor King 07/30/21 10:50PM
  Re: Building a ZA50.Re: Taylor King Taylor King 08/28/21 11:30AM
  Re: Building a ZA50.Re: * wormdirt * * wormdirt * 08/28/21 03:16PM
  Re: Building a ZA50.Re: Jacob Fulton Jacob Fulton 08/29/21 01:14AM
  Re: Building a ZA50.Re: Graham Motzing Graham Motzing 08/30/21 04:05PM
  Re: Building a ZA50.Re: Taylor King Taylor King 08/30/21 09:41PM
  Re: Building a ZA50.Re: Beach Club Nick Beach Club Nick 08/29/21 01:18AM
  Re: Building a ZA50.Re: P D P D 08/29/21 11:20AM
  Re: Building a ZA50.Re: Graham Motzing Graham Motzing 08/29/21 12:19PM
  Re: Building a ZA50.Re: Taylor King Taylor King 08/29/21 12:38PM
