> LSLB RXb Wrote:
> i’ve gone back to the middle rate springs that came with the clutch. the
> engagement was too erratic & was giving me problems getting into 2nd
> gear.
> i would say that you should get those malossi springs & you’ll 100% find
> something that works. the whites are probably engaging at like 6500rpm &
> they are the lowest strength in that pack. if i made more rpms, i would
> probably like the white springs more.
> all of this really makes me long for a 2nd gear with easily tunable
> springs like the jammer to play with. maybe some day
Yea something like the Stage6 tuneable clutch would be dope.
I have the pack of malossi springs with white/red/yellow on the way, along with an 8p Stage6 reed to replace the 4p Malossi VL6. Will try white springs first and see how it likes it - another 1k later RPM would be almost perfect, which sounds like it would be the white springs.
This thing is gonna be a rocket once I get that shift RPM drop taken care of. (edited)
