Tomos Jammer
LSLB RXb /
So Ok, I've started using a Tomos Jammer and it's been pretty sick after giving it a slight amount of prep.
Setup is a35 bottom end, stuffy crank with c4 clearance bearings, 64cc airsal kit (no casematch), doppler er2 reed, MLM 15mm SHA intake, CDI with Parmakit box, 15mm SHA with a #75 jet and solid #2 metal slide, full mesh filter element with Minarelli Style Airbox, HUNTER PIPE, balanced 1st and 2nd gear, lathed clutch bell, 2nd gear has the $33 shoes with stock green spring 9.5lb spring. I'm running 26x24 gearing on a 3" knobby tire streetmate rear wheel. I'm hitting somewhere around 43-45mph, but in a REAL hurry.
I threw it into my bike with no prep and the lightest springs from the factory and it was OK. I was having some issues with erratic engagement so I pulled everything apart to take another look at what was going on.
First thing i noticed was that the bolt heads very lightly were hitting my clutch bell.
I added the shim that comes with the clutch, buttoned everything up and started to test. I was not very happy with how the transmission felt after that so I opened everything up again and took another look.
I decided to ditch the shim and take down the heads of the bolts that had been hitting the clutch bell previously. No problem here, just use a bench grinder and take them down the slightest bit until they are flush with the face of the hub.
Next, I noticed that 1 out of the 3 spots for shoes was a tighter than the others and wasn't allowing one of the shoes to engage easily. No problem here either, I grabbed a hand file and filed away the top and bottom plates that sandwich the hub until a clutch shoe had smooth, free movement.
I reassembled everything and greased the area on the hub where the shoes lock into and we were back in business.
Bike rips, absolute blast, love it. Great take off, blip shifts into second wonderfully. More than fast enough for a city ripper.
I'm still testing this with the lowest engagement RPM springs, but I think I'm going to open up my transmission tonight to see how things look and to toss in the middle RPM springs to see how the bike likes it.
Does anyone have any clutch spring recommendations other than what come with these stock?
I know the malossi ones for the puch jammer are like NEXT LEVEL compared to stock and was wondering if anyone had any leads!
I'll probably go picking through what we have any see if anything works myself, but I figured I'd start a thread about this sort of thing.
If anyone has cool and fun experiences with this clutch, feel free to post here. I'll be adding some pictures and stuff later once I tear my trans cover off.
  Tomos JammerTopic by: LSLB RXb LSLB RXb 04/21/21 12:37PM
  Re: Tomos JammerRe: Jay Rivett Jay Rivett 04/22/21 10:11AM
  Re: Tomos JammerRe: Nick MBC Nick MBC 04/22/21 11:07AM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 04/22/21 11:36AM
  Re: Tomos JammerRe: Brent Bhuiyan Brent Bhuiyan 04/22/21 12:25PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 04/24/21 10:32AM
  Re: Tomos JammerRe: EH FCC of the QCB EH FCC of the QCB 04/24/21 10:43AM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 04/27/21 10:42AM
  Re: Tomos JammerRe: EH FCC of the QCB EH FCC of the QCB 04/28/21 04:34PM
  Re: Tomos JammerRe: Mark Alan Mark Alan 04/28/21 04:17PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 04/29/21 11:15AM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 04/30/21 07:58PM
  Re: Tomos JammerRe: Hepatitis J [OFMC] Hepatitis J [OFMC] 05/01/21 12:20PM
  Re: Tomos JammerRe: Jay Rivett Jay Rivett 05/03/21 07:15AM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 05/03/21 09:36AM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 04/30/21 11:00PM
  Re: Tomos JammerRe: EH FCC of the QCB EH FCC of the QCB 04/30/21 11:02PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 05/01/21 12:39AM
  Re: Tomos JammerRe: Mark Alan Mark Alan 05/01/21 03:52AM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 05/01/21 06:55PM
  Re: Tomos JammerRe: Mark Alan Mark Alan 05/02/21 01:52AM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 05/01/21 07:28PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 05/02/21 07:51AM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 05/03/21 04:12PM
  Re: Tomos JammerRe: EH FCC of the QCB EH FCC of the QCB 05/03/21 05:13PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 05/08/21 09:19AM
  Re: Tomos JammerRe: Puck FNT Puck FNT 05/17/21 02:21PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 05/23/21 10:22AM
  Re: Tomos JammerRe: Puck FNT Puck FNT 05/30/21 12:31AM
  Re: Tomos JammerRe: Puck FNT Puck FNT 06/04/21 09:05PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 06/06/21 09:56PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 06/07/21 12:48AM
  Re: Tomos JammerRe: Nick MBC Nick MBC 08/30/21 10:53PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 09/01/21 02:47AM
  Re: Tomos JammerRe: Nick MBC Nick MBC 09/06/21 11:30AM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 09/06/21 12:15PM
  Re: Tomos JammerRe: Nick MBC Nick MBC 09/06/21 08:10PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 09/06/21 08:24PM
  Re: Tomos JammerRe: Nick MBC Nick MBC 09/06/21 08:33PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 09/07/21 12:57AM
  Re: Tomos JammerRe: Nick MBC Nick MBC 10/08/21 04:41PM
  Re: Tomos JammerRe: LSLB RXb LSLB RXb 10/08/21 08:14PM
